Generate a report
You can generate the reports from several areas of the Enterprise Manager.
Procedure
  1. Do one of the following:
  2. Click Reports.
    A list of reports appears.
  3. Select the type of report to generate.
  4. Set any required report parameters or filters.
  5. Click Generate Reports.
  6. You can use any of the following buttons in the report screen to work with the report:
    • Export - Select this button to export the generated report to a Microsoft Excel Comma-Separated Values (CSV) file.
    • Printer Friendly - Select this button to format the generated report for printing. After you select this button, click the Print button at the top of the report window to print the report.
    • Back - Select this button to return to the previous window.
Overview of the reports
Enterprise Manager report descriptions
Data Source Details Report
Device Detail Activity Report
Device Summary Activity Report
Employee Detail Activity Report
Employee Summary Activity Report
Employee Data Source Association Report
Installation Details Report
Installation Summary Report
Member Group Summary Report
Rules Details Report
Rules Summary Report
Version Report
