Move a Site Group, Site, or Server (Installation)
You can move Site Group, Site, and Installation (or Server) nodes to rearrange these items within the Installations tree.
Procedure
  1. Go to System Management . Under Enterprise, select Settings.
  2. In the Installations pane, select the Site Group, Site, or Server node that you want to move.
  3. Click More Actions.
  4. Do one of the following depending on which node of the Installations tree you selected in the Installations pane:
    • If you selected a Site Group, click Move Group.
    • If you selected a Site, click Move Site.
    • If you selected a Server, click Move Installation.
  5. The target Move window displays, showing all eligible Site Groups or Sites to which you can move the selected node.
    In a Multi-Tenant SaaS environment, only the following Site Groups and Sites display in the target Move window:
    • Site Groups and Sites that are associated with the same tenant as the node you are moving
    • Site Groups and Sites not associated to any tenant
  6. Select the target node for the move, and then click Move.
    The Site Group, Site, or Server is moved under the target node in the Installations tree. All associations among servers are retained.
Moving an Installations tree node
Create and manage Installations tree nodes
Manage the Installations tree
