Complete the prerequisite tasks for creating an application server cluster
Task 1 of 2 required to create an application server cluster.
This task describes all prerequisite tasks you must complete before you can create an application server cluster. These tasks include installing:
A database server
The application servers that form the cluster
The load balancing device that handles connections to the servers in the cluster.
Perform the prerequisite tasks in this order:
Install the database to which the application servers connect.
Install the first application server (called Server1 in this example) and connect it to the database. The first server installed is the primary server in the cluster.
Install the additional application servers that are the other members of the cluster. Connect each of these servers to the same database server as Server1 installed in the previous step.
Activate the license on Server1 for the number of servers that operate as part of the cluster.
Install the load balancing device.
Next task:Create the application server cluster in Enterprise Manager
