Stream Recording member group settings
The following settings are available to the Stream Recording member goup.
Setting |
Description |
Name |
Type a unique name for the member group. |
Description |
Type a description for this extension group (optional). |
Recorder Control Type |
Recorder Control Type: The method used to record assigned to a given member group. The following options may be listed for the selected data source Third-party systems that provide data to the system, including employee and device states, and data change events. Typical data sources are phone switches, PBXs, or LANs.:
For Twilio Flex, only Selective Delivery is available. For Zoom Contact Center, only Full Delivery is available. |
Recorder Load Balancing Type |
By default, Recorder Load Balancing is set to None and cannot be changed. The Recorder Integration Service balances the call load to the recorders. |
Recorder Fallback Type |
Recorder Fallback Type options include:
Shared Recorders |
Select one or more IP Recorders to associate to this resource group. |
Shared Recorder Adapter Proxy Service |
Select one or more Recorder Adapter Proxy Service (RAPS) server roles to associate to this resource group. The RAPS and IP Recorder must be collocated on the same Shared Recorder. A correct association includes the Recorder Adapter Proxy Service + IP Recorder. |
Advanced Parameters |
Use the Key and Value fields to enter the advanced parameters required for your system. Only add advanced parameters in consultation with Verint Support or Field Engineers. |
