Registration and device failures
If you configure invalid extensions (or an extension that the T-Server is not yet aware of) the integrations will periodically attempt to re-register the DNs.
If a device fails to register, an alarm will appear in the Recorder Manager in the Integration Service section. You can also query failed devices in Recorder Manager.
Configure pause recording on hold
