Streaming Media Capture Pool member group settings
Use the Streaming Media Capture Pool resource group to capture call media in real time from a Streaming Media Capture server. This member group can be used with the following Application capture sources: Generic and Avaya Experience Platform.
The Avaya Experience Platform (AXP) Application capture source is for integrating an Avaya XP cloud environment that uses the Streaming Media Capture (SMC) API.
Setting |
Description |
Name |
Enter a unique name for the member group. |
Description |
Optional. Describe the group. |
Recorder Control Type |
Full Time Recording: The Recorder automatically starts recording each SMC connection that it receives. The Recorder Integration Service keeps or discards call audio based on real-time event notifications and the fallback mode, making it more resilient to logical errors and failures. For an Avaya XP application data source Third-party systems that provide data to the system, including employee and device states, and data change events. Typical data sources are phone switches, PBXs, or LANs. and an MPC system, select Full Time Recording. Selective Recording: The recorder does not automatically start recording each received SMC connection and must be commanded to start and stop each connection. The Recorder Integration Service commands the recorder to enable and disable the streams based on the real-time event stream. |
Recorder Load Balancing Type |
Select one of the following:
Recorder Fallback Type |
Streaming Media Capture Identifier |
This setting contains a Globally Unique Identifier (GUID) that identifies this specific configuration on the Streaming Media Capture interface. The GUID is automatically generated when the member group is created. You can change the GUID during creation, but it is uneditable after the member group is saved. |
Participant Configuration |
Select one of the following: External Participants: Captures the customer's audio. There must be a member group that captures the external participants. Internal Participants: Optional. Captures the agents on the consultative segment of a customer call. |
Correlation Key |
Create a Correlation Key to use an attribute other than the default (see your Integration Guide for details) to establish an association between a call recording and its CTI attributes. A Correlation Key allows the Integration Service to associate the CTI attributes of a call with the call recording in custom configurations. When a call is received by a data source in a SIP recording environment, the following occurs:
The Correlation Key associates a CTI attribute with a matching value in a SIP header field. To create a correlation key:
Example: The following example illustrates the use of a Correlation Key:
In this scenario, to create the Correlation Key, select SomeID as the CTI Attribute, and specify Vendor-SomeID as its associated Recorder Attribute in the text box. |
Notes:
Shared Recorders |
Associate one or more IP Recorders to this member group. |
Associated Recording Profile |
Select one or more recording profiles for this member group. To capture the agent-to-agent parts of a customer call, you can associate multiple recording profiles to the same Streaming Media Capture Pool member group. |
Advanced Parameters |
Use the Key and Value fields to enter the advanced parameters required for your system. Only add advanced parameters in consultation with Verint Support or Field Engineers. |
Configuration, overview, and limitations (Avaya Experience Platform Integration with Recorder)
