Install and configure Archive
Workflow sequence
Workflow: IP-based voice and video recording: Task 8 of 8
Workflow: Screen recording: Task 7 of 7
Dialer integration: Task 7 of 7
Before you begin
Detailed guidance for setting up and configuring Archive is found in the related information section.
Procedure
For enterprise-level Archive, enable the Central Archive role, either on the Recorder server or on a separate server.
For local Archive, the Local Archive role is enabled by default during installation.
Set up the Archive server to Recorder associations.
Configure Archive.
Recording configuration workflows
Archive Administration Guide
