Device Location member group Settings
The following applies to certain Trading systems only.
Field |
Description |
Name |
Member group name (required). |
Description |
Description of the member group (optional). |
Recorder Control Type |
Set to Full Delivery (External Controlled) (display only). |
Recorder Load Balancing Type |
Set to Media With Signaling (display only). |
Recorder Fallback Type |
Set to Always (Liability) (display only). |
Default Location |
Main device location. Each data source Third-party systems that provide data to the system, including employee and device states, and data change events. Typical data sources are phone switches, PBXs, or LANs. can have one default device location. The recorders assigned to the default device location resource are used to record turrets whose device location does not match another device location member group. |
Device Location |
One or more location strings can be added for member groups created for remote sites. Member groups for the default location (main site) do not use the location string since the Default Location setting is already enabled. The location string is case sensitive. |
Shared Recorders |
IP Recorder server roles that will record turrets at this location. |
Advanced Parameters |
Use the Key and Value fields to enter the advanced parameters required for your system. Only add advanced parameters in consultation with Verint Support or Field Engineers. |
