DMCC recording group member group settings
This member group is used in Avaya DMCC environments to support Avaya record on demand. It contains both the extensions being recorded and the resources (or DMCC soft phones) used to capture the audio recording. You can assign a pool of IP Recorders to this member group. The assigned resources are load balanced across the pool of assigned IP Recorders.
Setting |
Description |
Name |
Type a unique name for the member group. |
Description |
Type a description for this extension group (optional). |
Recorder Control Type |
The parameter is always set to Record on Demand and cannot be changed. This type supports the Avaya record-on-demand functionality. |
Recorder Fallback Type |
In multiple registration environments, fallback options are limited to those in which audio recording continues in the event of CTI or recorder disconnection from the Integration Service. Select one of the following from the drop-down list:
Recording Beep Tone |
Recording Beep Tone: When enabled, participants on a call hear a beep when the Recorder starts recording the call. By default, the beep tone is disabled. To enable this option, select the check box. Note: The duration, pitch, and repetition of the tone are configured in Avaya Communication Manager. |
Assigned Recorders |
Select the Avaya recorders to be associated to this member group. Select multiple recorders to create a pool of recorders to support the Avaya record-on-demand functionality. |
Assigned Phones |
The extensions assigned to the member group. Extensions are associated to the DMCC soft phones. Click the Assign & Create Phones button to assign extensions to the member group. |
Assigned Resources |
The DMCC soft phones assigned to the member group. The assigned DMCC soft phones are used to capture the audio recording. To add phones to this member group, click Assign & Create Resources, select the DMCC soft phones to add to this member group, and then click Save. After adding or removing phones and resources, or when the recorder capacity changes, use the Rebalance Resources option to distribute the load of resources (soft phones) evenly across the pool of assigned recorders. |
Advanced Parameters |
Use the Key and Value fields to enter the advanced parameters required for your system. Only add advanced parameters in consultation with Verint Support or Field Engineers. |
