AudioHook Recording member group settings
Setting |
Description |
Name |
Type a unique name for the member group. |
Description |
Type a description for this extension group (optional). |
Recorder Control Type |
Recorder Load Balancing Type |
The setting None is selected by default and cannot be changed. The Recorder Integration Service will internally load balance the calls to the recorders. |
Recorder Fallback Type |
Select one of the following:
Shared Recorders |
In this section, you must associate one or more IP Recorders with this member group. |
Shared Recorder Adapter Proxy Services |
In this section, you must associate one or more Recorder Adapter Proxy Service server roles with this member group. The Recorder Adapter Proxy Service server role Entity that contains a logical, predefined set of components (system software or certified third-party software) deployed in the Data Center and Site Zones that provide specific functionality for the system. must be on the same server as the Recorder server role associated to the member group in the Shared Recorders setting. A correct association includes the Recorder Adapter Proxy Service + IP Recorder. |
Advanced Parameters |
Use the Key and Value fields to enter the advanced parameters required for your system. Only add advanced parameters in consultation with Verint Support or Field Engineers. |
